please help!
Old Jul 4, 2006 | 11:07 PM
stevethecivicguy's Avatar
Default please help!
ok I recently changed the head gasket on my 93 honda civic I took the head in and got it pressure tested and milled. it came back good I got new gaskets and put it all back together when I started it, it had a really bad idle and when I give it gas it will die I have no idea what to do or what could be wrong any help would be awesome thanks in advance guys
Old Jul 5, 2006 | 07:57 AM
Chimera02EX's Avatar
Default RE: please help!
That is similar to what has happened to me when I swapped my manifold, except my idle isn't bad, not too long after I tried various different things pertaining to fuel, amount of air flow, my crank position sensor threw a code, so my plans are to replace that, make sure the timing is correct and go from there. I think my timing is off (not sure how I managed that without a distributor...).
DontHateOnEG8
20
Sep 6, 2008 06:49 AM
dhdicato
Apr 14, 2008 07:25 PM
D16racerchick
Jan 3, 2008 05:15 PM
redridinhood
Oct 9, 2006 07:27 PM
Honda99Civic
Apr 20, 2006 10:13 PM
