please help me
Old Mar 19, 2008 | 07:10 AM
siracer07's Avatar
Default please help me
can anyone out there help me i needsome infoi have a 00civic si b16a2 and i want topaint my valve cover the gasket is rubber do i need to replace it?
Old Mar 19, 2008 | 03:20 PM
Blue Canon's Avatar
Default RE: please help me
Couldn't hurt for the extra $30, might as well do a good job on it. Depends on how it looks when you get it out. Check around the cover before you pull it off. If there's no evidence of leaks, you might be ok... I'd just get a new one though.
Old Mar 19, 2008 | 07:35 PM
AgentofDarkness's Avatar
Generally you don't want to reuse old gaskets. There is a much higher likelyhood of leaks of you reuse a gasket. When I've reused gaskets in the past, I've put RTV around the gasket (both sides). You have to be carefull with this though. Don't get it in the bolt holes and make sure it doesn't get into the cylinder head it self.
DontHateOnEG8
20
Sep 6, 2008 06:49 AM
dhdicato
Apr 14, 2008 07:25 PM
D16racerchick
Jan 3, 2008 05:15 PM
redridinhood
Oct 9, 2006 07:27 PM
Honda99Civic
Apr 20, 2006 10:13 PM
