power from b20
Old Feb 12, 2007 | 11:12 AM
heymikey19's Avatar
Default power from b20
i have a 99 civic with a lightly modded gsr motor( intake, exhaust, headers, fuel rail, cam gears). iv been thinkn of a b20 and maybe getting one. what kind of numbers could i expect from one with the same mods. what kind of qtr mile time etc. thanks
Old Feb 12, 2007 | 11:19 AM
Powermidget's Avatar
Default RE: power from b20
why not just get a1.9/2.0stroker kit for your gsr motor....and if your got the b20 would you be swapping the gsr head on it or just those listed mods non vtec....if no vtec head you pobwont be as fast as you are now
Old Feb 12, 2007 | 11:37 AM
heymikey19's Avatar
i would just use my head if i did it
Old Feb 12, 2007 | 11:44 AM
Marty's Avatar
what kind of numbers you pulling now?
Old Feb 12, 2007 | 11:54 AM
heymikey19's Avatar
never been on a dyno but around 14.3 in the quarter
Old Feb 12, 2007 | 12:33 PM
if you get the b20 with the vtec head you should be able to hit high 13s
Old Feb 12, 2007 | 12:40 PM
heymikey19's Avatar
how would that compare with the stroker kit u talked about. while keeping in mind this is my daily driven car and i cant hurt the reliability of my motor for power
Old Feb 12, 2007 | 03:01 PM
if you just got the 1.9 strokerKIT you would not be majorly affecting your reliablilty...you will prob get better times out of the stroker and tho you are slightly weakening your motor with the bore that should be more reliable if done correctly than a b20 vtec conversion...
now if you go any larger than 1.9/2.0 you may have some additional work ahead of u.
if you were planning on boosting get the b20(reliable with boost and a stock head)....if you want to stay na get the stroker kit for your gsr
personally i would stroke your gsr motor
Old Feb 12, 2007 | 03:39 PM
Marty's Avatar
Hell I'd just throw a turbo setup on the gsr and call it a day.
Old Feb 12, 2007 | 03:58 PM
heymikey19's Avatar
not that a turbo wouldn't be great but im really trying to keep this buildn/a and not boost it. just my preference. another ? i have then is would switching to itr pistons and rods be comparable. or is that overrated as some people have told me.
