Radiator Leak
Old Feb 20, 2006 | 04:12 PM
irishblue's Avatar
Default Radiator Leak
I have a 97 Civic Lx, I noticed some white smoke coming out of the hood, and when I checked I noticed I was out of coolant. So after the car cooled off I refilled it with coolant and ran the engine, I noticed coolant slowly gathering on a sponge-like gaurd at the top of the radiator, is my radiator busted? How hard is that to fix?
Old Feb 20, 2006 | 04:32 PM
DJYoshaBYD's Avatar
Default RE: Radiator Leak
you might have a bad theromostat... is the water boiling when it comes out?
Old Feb 20, 2006 | 06:25 PM
irishblue's Avatar
It's not boiling. Its just as the engine gets warm, the coolant leaks out. The coolant is warm to the touch.
Old Feb 20, 2006 | 09:45 PM
natecivic92's Avatar
You need to do a pressure test.If it is the tank the plastic piece, that can be replaced it is easier just to replace the whole thing I have a 92 and it takes me like ten min or less to remove it.
Old Feb 27, 2006 | 03:36 PM
j_civic_ex's Avatar
I have a 98' ex and the plastic part of the radiator cracked a few days ago. it was right by where the foam stuff is. i replaced it with a radiator that i bought from autozone. it's wider than the stock one but works great. it cost me $103 and comes with a limited lifetime warranty. it's an alternative that ain't too expensive.
Old Feb 27, 2006 | 07:10 PM
A bigger radiator is a good thing.
1995civicdxtpa
12
Jan 3, 2010 11:42 AM
Carbo
Oct 19, 2009 06:05 PM
silverbullet01
Aug 28, 2008 12:51 PM
mokijo2
Dec 27, 2007 12:11 AM
gmb
Sep 26, 2005 12:36 AM
