SAWP OR NO SWAP?
ok i have a 96 civic should i sell it and try to buy a civic si 96 or swap a b18c5 for my engine and fix it up? or should i keep my sohc and turbo it?
RE: SAWP OR NO SWAP?
do the swap to b16a and keep it lookin stock... then s/c it to smoke bimmers on a bad day with your civic!
hmmm s/c???? bimmers?? how much will this cost...and where should i get it?
theres a 96 si pretty sure sohc v-tec boost it about 2 to 4 g's
the b18c5 swap about 4 g's getting a newer car thats faster but less pain in da ass priceless lol :D |
iight to be more specific here are some of the choices of swap you can do to the 96 civic.
B18C5 (Type-R),B18C1,B16A2,B18B1 Bolt-in swap Requires 99-00 Civic Si Rear mount Requires wiring harness modifications. B17A Requires hyraulic transmission or HASport cable clutch conversion Kit Requires 99-00 Civic Si Rear mount Requires wiring harness modifications OBD-1 ECU adaptor needed B16B (Civic-R) Bolt-in swap Requires wiring harness modifications for LHD cars note that if civic is not v-tec you may need a v-tec controller like an apexi controller or wire the v-tec to a switch of some sort. also b-series trannys are needed with the motor and axles and ecu's maybe wire harnesses. the swaps can run from $2,000-$6,000 it all depends where you get it from and who you get it done by. |
ORIGINAL: karlos0221 ok i have a 96 civic should i sell it and try to buy a civic si 96 |
bingo
