SAWP OR NO SWAP?
Old Jun 25, 2005 | 10:29 PM
karlos0221's Avatar
Default SAWP OR NO SWAP?
ok i have a 96 civic should i sell it and try to buy a civic si 96 or swap a b18c5 for my engine and fix it up? or should i keep my sohc and turbo it?
Old Jun 25, 2005 | 11:53 PM
Remmy's Avatar
Default RE: SAWP OR NO SWAP?
do the swap to b16a and keep it lookin stock... then s/c it to smoke bimmers on a bad day with your civic!
Old Jun 26, 2005 | 03:11 AM
karlos0221's Avatar
hmmm s/c???? bimmers?? how much will this cost...and where should i get it?
Old Jun 29, 2005 | 03:11 AM
hondabboy's Avatar
theres a 96 si pretty sure sohc v-tec boost it about 2 to 4 g's
the b18c5 swap about 4 g's
getting a newer car thats faster but less pain in da *** priceless lol
Old Jun 29, 2005 | 10:43 AM
hondabboy's Avatar
iight to be more specific here are some of the choices of swap you can do to the 96 civic.
B18C5 (Type-R),B18C1,B16A2,B18B1
Bolt-in swap
Requires 99-00 Civic Si Rear mount
Requires wiring harness modifications.
B17A
Requires hyraulic transmission or HASport cable clutch conversion Kit
OBD-1 ECU adaptor needed
B16B (Civic-R)
Bolt-in swap
Requires wiring harness modifications for LHD cars
note that if civic is not v-tec you may need a v-tec controller like an apexi controller or wire the v-tec to a switch of some sort. also b-series trannys are needed with the motor and axles and ecu's maybe wire harnesses.
the swaps can run from $2,000-$6,000 it all depends where you get it from and who you get it done by.
Old Jun 29, 2005 | 01:57 PM
ohbiskits's Avatar
ORIGINAL: karlos0221
there isnt a 96-98 si...at least to my knowledge....si went out in 95 and came back in 99
Old Jul 9, 2005 | 02:26 PM
Roost3r's Avatar
bingo
fats96civic
EG Swaps
Jan 13, 2007 06:28 PM
sleepin stock
EK Swaps
Nov 16, 2006 10:35 AM
WhiteCivic15
Jul 7, 2006 03:17 PM
00civicEX_3
EK Swaps
Feb 26, 2006 11:08 PM
nemesis08
Jun 8, 2005 08:05 PM
