SCREW IT
Old May 25, 2006 | 03:55 PM
F23AccordLX's Avatar
Default SCREW IT
OK, i need to know, not many people know this. I am doing a D16Z6 swap into my 97'
Civic EX. I want to know if i use the manifold off the D16Y8 w/ injectors, fuel rail, throttle body will it run? Are there any different coolant lines that have to be re-routed. I am using my manifold off the D16Y8 w/ injectors, fuel rail, throttle body, the Y8 dizzy (I know, only two bolts line up but it will work for now), power steering pump bracket (I also have the one for the D16Z6, A/C bracket (I also have the D16Z6 A/C bracket). Will all of this work??? I am also running a OBD2 to OBD1 conversion harness w/ a P28 ECU to bypass the sensor in the timing cover of the D16Y8. I need to know if this will run right!!! I've heard that the D16Y8 dizzy will time the motor 4.5 degrees (advanced or retarded, i don't remember) but will it run with the timing advanced? HELP!!!
Old May 25, 2006 | 05:16 PM
Default RE: SCREW IT
bump
Old May 26, 2006 | 01:14 PM
Nail I3unny's Avatar
everything should work...but you should use a z6 dizzy.
Old May 26, 2006 | 11:57 PM
97civicturbo's Avatar
yeah the car will run like **** without the right distributor.
jonyg98civicex
Apr 6, 2006 08:09 PM
tzcivic
Jan 23, 2006 10:33 PM
drbyers
Jan 9, 2006 04:31 PM
paintballoma
Sep 13, 2005 10:18 PM
alan4359
May 18, 2005 07:51 AM
