So at what point...
At what stage of N/A builds will the fuel mileage go down?
From what I can guess, once you move to a larger injector or increase compression you're going to start loosing fuel efficiency, also if you hog out the head a lot. Any thoughts? On the other hand, I/H/E, mild head porting, or a cam shouldn't effect it from what I can tell... but increasing compression is causing more resisitance to the rotation of the crank, and typically larger injectors don't atomize as well. |
RE: So at what point...
To tell the truth on our engines loss in your milage will be slim depending on the tune.
