Some car troubles still not solved please help
sup everyone i have a 93 civic with b16a2 mid built. cams/shafts/etc. But no after market dizzy or plugs or anything. but anyways to the point.
My car recently on idle it will shudder like its almost out of gas and when throttled sounds like its got a miss-fire but i pulled the plugs and it was somewhat black, so i know the car is running rich, then recently i was getting on the freeway and hit vtec and my friend said he saw some black smoke out the back pipe.
i recently drilled a small pin hole in my exhaust at the lowest point on muffler so water can leak out. But anyways back the the point it sounds like its got a miss-fire on cold idle. and then when i throttle it to like 4 grand it seems like all 4 cylinders are miss-firing.
but when it warms up it clears out, it sounds alot like all the cylinders are getting loaded. i talked to my father-in-law a 31 year ford motor tech mechanic 3 time master. and he says it seems like you need a hotter burn, and the cylinders are all getting loaded on a cold idle.
Anyways i have NGK plugs in the car and i was wondering if anyone knows a plug one step up with alittle hotter burn cause it seems like i'm getting a lot of fuel and after it ignites in the cylinder it seems like I'm getting little bit a fuel residue. PLEASE PLEASE PLEASE SOMONE HELP ME IN THIS ISSUE. i need to know a better spark plug. p.s i apologize if this hurt anyones eyes i tried to sort out the paragraphs as much as i could
__________________
__________________
ic892003
26
Jul 19, 2007 06:24 PM
Impreza WRX
May 7, 2006 02:01 PM
forcefedcivic27
Aug 23, 2005 12:37 PM
Readyforthepasture?
Nov 6, 2004 09:57 AM
