swap question CLICK HERE!
Old Oct 4, 2007 | 11:51 AM
jdm92civic's Avatar
Default swap question CLICK HERE!
i'm thinking about putting a JDM d15b into my 92 lx.
i copied everything from another website but here's the stats. wat else do i need?
• Make: Honda
• Engine Code: D15B
• Year: Honda Civic 92-95
• Valve Train: SOHC, V-TEC, 16 Valve
• Horse Power: 125hp@6600rpm
• Torque: 106lbs-ft@5200rpm
• Redline: 7000rpm
• Transmission: 5 Speed
• Displacement: 1590cc
• Mileage: Approximately 25-35 Thousand Miles
• Condition: Best
• Included: Complete Motor
Complete Head & Block
5 Speed Transmission
Distributor, Intake Manifold
Exhaust Manifold, Alternator
Power Steering Pump
Fuel Rail, Injectors, Starter
Throttle Body, V-TEC Solenoid
Old Oct 4, 2007 | 03:24 PM
warner_ro's Avatar
Default RE: swap question CLICK HERE!
is there a reason why maybe a b series, like b16 wouldnt work? i am a fan of those.
Old Oct 4, 2007 | 04:17 PM
**Alan**'s Avatar
money is the problem with most people but others like SOHC or may be they just like D series
Old Oct 4, 2007 | 05:13 PM
jdm92civic's Avatar
^ money isnt that big of a deal. it's just that the car is "92" i don't wanna spend that much money on it. a jdm d15b would be fine and maybe during the spring drop in a turbo or something. but i was just wondering wat else i need to do the swap. i heard i can use my stock tranny but it has already about 200k miles so idk.
Old Oct 5, 2007 | 06:29 AM
jdm92civic's Avatar
bump
Old Oct 5, 2007 | 11:09 PM
Everyday Getaway's Avatar
Definatly swap out that tranny if you're going to do the swap... the tranny is only like, $200 extra, OR you COULD look around a little harder and find one with LSD for a little more cash. As far as what else you'll need... I'm not possitive, but that sounds like it, the d15b is essentially the same thing as a d16z6, so it should be pretty straight forward, correct me if I'm wrong...
Old Oct 6, 2007 | 05:09 AM
mxs's Avatar
mxs
you need to do some wiring, and get a new ECU
Old Oct 7, 2007 | 10:52 AM
jason_guy_yeah's Avatar
If you feel like tearing your tranny apart, you could replace your main and secondary shaft bearings as needed; and replace the syncros. This would be much cheaper and some insurance.
Section8
Jun 22, 2010 07:44 AM
dj_ipirate
Jan 8, 2006 12:57 PM
Pete
Oct 7, 2005 04:46 PM
xe1002
Sep 4, 2005 09:37 PM
88HonCiv
Mar 7, 2005 03:15 PM
