th3c1v's 2000 hatchback dx special SiR swap
Alright im planning on doing a 2000 honda civic sir b16a2 engine swap into my 2000 honda civic hatchback dx. They are both canadian cars and the same year, I have no clue the parts i will need to do this engine swap. What type of wiring harness do i buy? and i want my car to be right around 200hp w/o a turbo so what would be some good parts to build the new engine up? would like some help and some ideas thanks.
you will need, shift linkages from the b series, motor mounts, trans mounts, trans, motor, axles, ecu
to get a good 200hp i suggest porting and shaving the head, cams, flywheel, stage 1 clutch and a good intake and exhaust
