Timing Belt Question; What is purpose of setting crankshaft to TDC?
Sorry this may be a ridiculous question to ask, but what is the purpose when doing the timing belt install in setting the crankshaft to the TDC?
I understand the reasons why I would do this when adjusting the valves so I could adjust the valve when the piston is fully compressed, but why with the timing belt? Is it so I could go back to that position if the crankshaft or camshaft accidently move during the install of the belt? I don't think I follow why this is done.
It's just a point of refernce. You can do it at 19*BTDC (or whatever) if you think you can get the crakshaft postion and cam in the EXACT right position. One tooth isn't gonna ruin your motor but it'll run like ***.
werd. ive heard of a guy who had a 600+hp mitsu and got a shop to replace the timing belt and the intake cam was off by one degree and he could barely get to speed on the highway without flooring it.
beat2hell93civic
Apr 5, 2011 04:22 AM
flattire
Aug 18, 2009 03:40 AM
babyivan
Jun 23, 2008 11:55 AM
