Timing question
:eek: For some reason my civic 95 DX auto knocks valves on third gear,
When I am picking up speed I hear the valves pinging. I have set the timing , Shorted the connector on the passenger side, the marks are perfect. The only thing weird is that the distributor is turned to the maximum settings foward. . I am not sure why my valves are ticking. I did adjust the valves to correct specs. Any Hints ? thanks :eek: |
RE: Timing question
set your timing were its sappost to be at. How do you know its the valves ticking maybe its detontion? have you done like a timing belt latly or anywork done to the motor that would make a ticking noise if not done correctly?
RE: Timing question
could just be the gas u got making it spark knock... riceburners question about the work done latley to...could need a tune up...
