turning over not starting
Old Sep 29, 2007 | 09:44 AM
ClinDiesel's Avatar
Default RE: turning over not starting
no i dont i can tell even if it was probably lol,i tried losing the bolt on the bottom of the fuel filter to see if it was sparying out but its not.
Old Sep 29, 2007 | 09:51 AM
ClinDiesel's Avatar
i just went out there yeah the fuel pumb is engaging buzzes for like 2-3 seconds
Old Sep 30, 2007 | 05:21 AM
jason_guy_yeah's Avatar
The only thing I can think of is, the pick up line on the fuel pump is disconnected. Or a clog in the fuel lines. Not sure.
Old Sep 30, 2007 | 10:10 AM
The obvious thing would be that the gas tank is empty.
If you hear the pump running but no gas comes up to the filter and there is plety in the tank, the next thing would be to disconnect the supply line back at the tank and try to blow air thru it to the filter end (also disconnected) or just pull the fuel pump out and look for disconnected lines inside the tank.
monkey808
Nov 15, 2013 06:00 AM
HondaTrex
Feb 5, 2009 04:51 PM
weez
Nov 24, 2007 01:04 PM
Azeluk
Sep 1, 2007 02:14 AM
HelpMyHonda
Apr 29, 2007 06:07 PM
