vtec not working??
i just got my car 2000 siR (si) and my vtec does not go off at all... im new to hondas and cars in general what could be the problem(s)? thanks
RE: vtec not working??
How do you know your VTEC is not working?
put oil in ur car. when ur honda gets low on oil the v-tec will not engage. trust me. my sohc did the same. i thought it was a vtec senaoild and it wasn't. by the tim ei found out it was too late. the with the heat these days u are bound ot be below 2 quarts and if ur blew 2 quarts it will not work.
U'd probably get better feedback, if u posted this in the engine forum. There r some very knowledgable people that help out there.
did you put your rpms up high enough so vtec will kick in? i think its 5800 rpms, if not that then it could be the selanoid.
Hey Daisoman how did you get that name? I used to do business translation with a huge 100 yen (dollar store) chain over in Japan called DAISO. Daiso is probably one of the funniest places in Japan because they literally have everything you could think of for only 100 yen! Let me know!
Are you saying this because you can't hear it? Or you know it's actually not working?
ok ive had the car since January and changed the oil twice.... i didnt really even know what vtec was until i drove my friends Sir then felt and heard it... he drove mine and said my vtec doesnt work... i have redlined it but still nothing. would it be the ECU because thats what i was told it could be the problem? and do u guys think this is going to be expensive? thanks!
If you redlined it, it should mean its working? What ECU are you using?
what engine........are you sure it even still has a vtec engine? also is the check engine light on and if so have you checked the codes? theres a few things that will not allow vtec to engage.
