vtec vs non vtec??
Old Aug 23, 2005 | 02:12 PM
mahmi's Avatar
Default vtec vs non vtec??
What differences can I expect when changing my stock engine to vtec? I have a 92 civic lx
Old Aug 23, 2005 | 03:53 PM
ngoti 8tor's Avatar
Default RE: vtec vs non vtec??
More power and faster car.
Old Aug 23, 2005 | 05:37 PM
Nail I3unny's Avatar
more power UP TOP. you prolly wont have more power down low, but depending on the head you swap on you might cuz it could increce compression a bit
Old Aug 23, 2005 | 06:49 PM
maddawg's Avatar
no technacal answers ??
Old Aug 23, 2005 | 09:54 PM
what do you want us to say? thats what the difference is gunna be. more power. unless your looking for an explination of VTEC in which case you should as for it :P
Old Aug 23, 2005 | 10:23 PM
mxs's Avatar
mxs
It will make it More Betterer
how's that for technical?
just kidding...
why don't you tell us more about your car, i.e. what you have done to it so far and what you want out of it?
Old Aug 23, 2005 | 10:27 PM
ORIGINAL: mxs
nice.
Old Aug 24, 2005 | 02:07 AM
maddawg's Avatar
i've only done cosmo stuff to mine ie tint and rood visoretc... i have plans for setember to get a magnaflow cat-back and AEM V2 maybe some headers in october
ORIGINAL: mxs
just kidding...
Old Aug 24, 2005 | 02:18 AM
Street Sniper's Avatar
V-Technical answers?
The vtec head flows better than the nonner in the first place, so even if the Variable valve and lift Timing Electronic Control were disengaged you would still see some gains. There is a sticky on here somewhere that explains the concept with a video if you wanna look around for it.
As far as differences- the biggest will be power. It's a good 20 Hp over the nonner, as well as continued torque into the rpm's where the nonner would normally drop like a rock.
Are you swapping engines or just the head? Becasue with the head swap you will also get just a smidge more compression over the stock vtec.
Old Aug 24, 2005 | 02:32 AM
ngoti 8tor's Avatar
Doesn't the VTEC engine rev higher also?
