what engine to boost?
Old May 5, 2005 | 09:34 PM
smokingemcee's Avatar
Default what engine to boost?
Ok, I have a 95 si and I wanna do an engine swap and boost it. I don't have a lot of money so I don't have a lot of options. What would be better to boost, a non vtec b18ls motor, or a jdm d15b vtec? I know vtec engines are higher compression, so is it bad to boost em? how many pounds of boost could i run on those motors? Which one would give me more preformance? holla back!
Old May 5, 2005 | 09:38 PM
LEVIII's Avatar
Default RE: what engine to boost?
I would do the b18. Even though a vtec would be better I would do the b18 because of its displacement
Old May 5, 2005 | 09:55 PM
Kappa22's Avatar
B18B (that's assuming the LS and the D15B are your only options...)
Old May 5, 2005 | 10:51 PM
sacicons's Avatar
i agree with them.
Old May 6, 2005 | 03:05 PM
315 Customs's Avatar
yea and also the ls is a much stronger block
Old May 13, 2005 | 03:21 PM
ricerocket's Avatar
Dude you can put an B18C1 engine in your car the moints fit fine and youll have 170 horses stock to work with.
Old May 13, 2005 | 11:50 PM
sacicons's Avatar
and it costs about 2x the cost of an ls swap.
Old May 14, 2005 | 02:00 AM
hondabboy's Avatar
get the gsr (b18c1) motor cause of v-tec thats it. you'll be happy
Old May 15, 2005 | 03:23 PM
Lets say I do the b18ci swap and decide to boost it later. How much boost can i run stock?
Old May 15, 2005 | 03:35 PM
hondabboy's Avatar
im pretty sure about 12-15psi...
