What engine do I have?
Old Feb 26, 2011 | 03:07 PM
Flipz's Avatar
Default What engine do I have?
I'm looking around to replace the engine in my 93 civic ex. Is it the d15b? Im looking for a direct replacement
Old Feb 26, 2011 | 03:11 PM
If it's the factory engine, it'll be a D16Z6. If you're looking for a used engine, try craigslist; you should be able to pick one up for around $300.
Old Feb 26, 2011 | 08:02 PM
Flipz's Avatar
Ok thanks, is there a spot on the engine where they brand the engine type? just in case its not the stock motor?
Old Feb 26, 2011 | 08:09 PM
MBrent's Avatar
July 2010 ROTM
look to the left of the exhaust manifold, theres a flat spot with the engine designation inscribed on it. stand by for pic edit...
d16z6ip9.jpg?1298783529
look in the red circle, theres a nice flat spot with the code on it
Old Feb 27, 2011 | 09:14 AM
Flipz's Avatar
i looked and found a bar code
S20 1583429, where can i find what that is? lol sorry im asking so many questions
Old Feb 27, 2011 | 01:35 PM
Sounds like you are looking at the transmission and not the engine.
The engine code should start with a D15 or D16. My guess is a D16z6.
Old Feb 27, 2011 | 03:11 PM
Should the timing belt cover not also have a sticker with the engine code (assuming the sticker is intact)?
Old Feb 28, 2011 | 07:24 AM
Flipz's Avatar
the sticker is faded and cant read what it once said, so i've been looking elsewhere for it
Old Feb 28, 2011 | 08:41 AM
All right, check the location in MBrent's picture. Chances are the trans. ID is stamped on the bell housing right next to the engine ID; look to the immediate right of where you saw "S20..."; S20 is the transmission ID.
Old Feb 28, 2011 | 10:23 AM
Flipz's Avatar
Found it! it was too the right of the code covered in grime. Thanks for your help it is a D16z6
