what kind of engine
Old Aug 11, 2005 | 01:27 PM
freebass's Avatar
Default what kind of engine
i want to get a new engine for 92 honda civic dx
what engine should i get & what other parts will i need to make it work
Old Aug 11, 2005 | 02:02 PM
hondabboy's Avatar
Default RE: what kind of engine
depends how much you wanna spend.
1.b16 swap = 2,000 everything needed(mounts if not included), require professional help with wiring and installing.
2.b18c1 aka GSR swap = 3,000-4,000 same as b16 maybe convert to obdII
3.V-tec head (easier) = 200-500 replace head with v-tec head off any d-series motor recommend y8 for more compression, wiring need.
4.h22 swap- = 2,000 convert obdII, also alot of wiring needed.
Old Aug 11, 2005 | 03:51 PM
freebass's Avatar
ive replaced motors before just never swapped a motor for a bigger better motor
do you still think ill need pro help?
Old Aug 12, 2005 | 05:26 AM
FD_Sauce's Avatar
if you can do all the wiring and mounts your self then go for it if your not sure get help
Old Aug 12, 2005 | 07:12 AM
freebass's Avatar
I'm having trouble finding a b16. What about a b16a?
I've found tons of them & they're JDM. Where on the net would you go to buy a motor?
Old Aug 12, 2005 | 10:02 PM
Nail I3unny's Avatar
b16 is a generalization. theres the b16a and the b16a2. the former is JDM, the latter USDM. if you can get a b16a...go for it. they usually have less miles on them than the USDM counterpart. and i think theres a bit more power in them. personally id rather go b18c or b18c1 and throw on a b16a2 head. but its up to you
Old Aug 13, 2005 | 08:29 PM
.adrian.'s Avatar
hey man..
i dont know why no one has said b18c5, it's an awsome engine. type r and it gives u about 210 horses stock. boreit out and itll give you more with other upgrades as well..
also some advice, i wouldn go with the h22, (h series) because its a killer to installand u have to take out power steering and ac. not worth it.
the only thing about this b18c5-r is that its expensive, about 4000-5000, but its worth it.
if that would be too expensive, i would go with a gsr b18c1 swap or a b16a
(although not as power full)
iight good luk mang
Old Aug 13, 2005 | 09:25 PM
b18c5 is good for an N/A car...but there are a lot of engines out there that are cheaper, easier to find, and better for boosting
it would be great if you dotn want a turbo
Old Aug 15, 2005 | 11:44 AM
freebass's Avatar
i think I'll go with the b16a its best for my price and I'll eventually put a turbo or a super charger on it.
what about a transmission. What kind of trans should i use with this motor?
jungo75
Jun 9, 2007 06:18 PM
02CivicEX
Jul 17, 2006 04:06 PM
civic_05
Mar 2, 2006 07:12 AM
95dx28
Jan 20, 2006 10:02 PM
krentigrboi
EK Swaps
Nov 12, 2005 11:58 AM
