Won't always start... Service engine light.
Hey guys... I am new to this site and was hoping that you could help me out here. I bought a used 1990 Honda Civic SI hatchback and I am having some troubles.
Typically when I start my car the Service light comes on for about 3 seconds and goes out (normal). After a short trip when I try to start the car again and turn the key to accessory power the service engine soon light will stay on for up to 5 min and my car won't start. The starter runs when I turn the key but it won't start. I am able to push the car and pop the clutch to get it to start. If I wait for a while (while staring at the light with a very intense focus *jks*) I hear a small click the the light blinks, then it sounds like a full relay click from under the dash and the light goes out. Then I can start the car. What is going on? I spoke with the local honda dealer and they thought it was the remaining components of an aftermarket alarm and engine immobilizer but I replace the alarm with a new one and all new components and it is still a problem. I have it booked into honda to see if is is storing a code for thursday but it is going to cost me a mint so any help would be appreciated! Thanks! |
you know you can take it to advance autoparts or autozone to get the codes pulled, right? For FREE!!! :D
yeah get in the zone.
autozone!
when the light comes on..... just come in.....
pepboys has everything you need for less! |
Sounds like a plan... but I have no autozone in my town.
Isn't there a way to connect a jumper wire and count the flashes or something? I know I could do that on my 88 Chev S10. |
Not too sure if it works on EF's, but here you go:
http://www.honda-tech.com/showthread.php?t=1901557 |
1 Attachment(s)
Sounds like a bad main relay, which provides power to the fuel pump.
A 1990 Civic has an OBD0 ECU, so AutoZone can't pull the CEL codes with a scan tool. But don't worry, you can easily pull the codes yourself: Attachment 18570 |
1 Attachment(s)
Thanks for the info on the codes! I will take a look after work...
Here is a picture of the relay that is clicking... it is located on the drivers side under the dash just behind the door hinge. Is this the main relay? Attachment 18569 |
1 Attachment(s)
The diagram below shows the location of the main relay. Yours is located equivalently on the left side.
Retrieving code 16 would verify a main relay problem. Attachment 18568 |
