y8 crank in zc block
i have a fresh built y8. the cylinder walls are bad as well as the rings. i have a good zc block that has a bad rod bearing. can i pull the crank and oil pump out of the y8 and throw it in the zc?
any ideas guys?? i know i would have 2 oil dip stick holes
the crank will drop in just fine. if you use the y8 oil pump use the y8 pan but im not %100 sure if the oil pump/pan will work
