y8 crank in zc block
Old Jul 3, 2009 | 05:13 PM
rocksbite's Avatar
Default y8 crank in zc block
i have a fresh built y8. the cylinder walls are bad as well as the rings. i have a good zc block that has a bad rod bearing. can i pull the crank and oil pump out of the y8 and throw it in the zc?
Old Jul 4, 2009 | 05:46 AM
rocksbite's Avatar
any ideas guys?? i know i would have 2 oil dip stick holes
Old Jul 7, 2009 | 12:39 PM
riceburner700's Avatar
the crank will drop in just fine. if you use the y8 oil pump use the y8 pan but im not %100 sure if the oil pump/pan will work
zerojett
Oct 18, 2011 03:01 PM
Lost
Apr 24, 2007 02:22 AM
ProjectGSR
Feb 26, 2007 05:46 PM
BillyB98
Aug 17, 2006 05:06 PM
turbob18c1
Mar 6, 2006 08:46 PM
