Yay or Nay!?!?
Old May 11, 2007 | 12:51 AM
ivtec's Avatar
Default Yay or Nay!?!?
Woot found my B18C1! I get the whole car(meaning plus chassis) but just that it was in a accident and the driver side doors are trashed, the engine is still good with no leaks btu with 115,000 miles on it.
Full swap:
Year: 1998 GSR USDM
Complete Engine
Transmission
ECU
Engine Harness
Shift Linkage
Axels
And Everything Else
Price: $2,000
Mileage: 115,000
Yay or Nay?
Old May 11, 2007 | 04:01 AM
Default RE: Yay or Nay!?!?
Run a compression test on it and see if its worth a ****
Old May 11, 2007 | 05:14 AM
riceburner700's Avatar
and if you can a leakdown
Old May 11, 2007 | 06:12 AM
FlipHKD720's Avatar
compression test, but if you can get an entire B18 plus chassis for $2000 i say go for it, fix the doors up and you'd be good to go
Old May 11, 2007 | 10:42 AM
ivtec's Avatar
Finished
Compression tested from 245-250.
I might jsut take the engine out and swap out my B16 if everyone thinks it's a good buy. Plus will the integra back rotors work for a drum->rotor back conversion?
Old May 11, 2007 | 11:14 AM
cderalow's Avatar
ORIGINAL: ivtec
Finished
i think you need whole rear trailing arm assembly, plus brake lines, plus new master cylinder & proportioning valve
other than that, if it passes compression & leakdown tests, snag it
Old May 11, 2007 | 11:37 AM
ivtec's Avatar
I don't know what the average compression test for a 98 GSR should be but yeah I got
245 245 248 250
If anyone knows what it should be at please do tell, thanks. I am just worried 115,000 miles lol.
And I should be able to get all those items for the back conversion on the teggy right?
Old May 11, 2007 | 11:43 AM
cderalow's Avatar
numbers look nice and strong, and within 10% of each other...
i'd ask if they recently rebuilt the engine and/or head, or completely babied the car & motor
nominal compression should be 270 I believe
Old May 11, 2007 | 06:47 PM
ivtec's Avatar
Just asked the car was stored during winters and driven on mostly on weekends. No re-built and I rechecked the engine again with no leaks at all and all timing belt sounds really good.
Old May 12, 2007 | 08:11 AM
SI2000's Avatar
the belts should be changed at 100,000 so find out if they have been. and also dont worry about 115,000 miles, on a honda thats just broken in
abzk01
Oct 15, 2007 03:12 PM
BillyB98
Sep 2, 2007 08:36 AM
Fiirkan
Jul 12, 2007 06:18 PM
MHSBaseball
May 9, 2007 10:22 PM
Phalcon
Mar 28, 2007 10:23 PM
