z6 and b7 distributor
Old Jun 4, 2009 | 03:55 PM
candyman420's Avatar
well i havent used the b7 timing belt yet but i was plannig on using it.. i didnt know it had more teath..... i didnt have the z6 head on when the timining slipped...
i havent done any wiring for the vtec yet i was gunna wait till i got the p28....
i wasnt planning on doing the mini-me swap the salvage yard sent me the wrong head so i figured i would just use it since i got it for 75$....how much of a hastle is it to wire the vtec when i get the p28?
Old Jun 4, 2009 | 04:20 PM
There are two wiring harnesses on the VTEC solenoid, with 1 wire on each harness (or you may be missing the harnesses... in that case you'll need to buy some. Junkyard is the best place to look, just get the pigtail harness.
You take those two wires, and run them to their corresponding places ECU. You only need to worry about pins A4 and D6, ignore the rest.
Alternatively, get a 92-95 EX or Si engine wiring harness and swap that in, and plug n' play.
Old Jun 4, 2009 | 04:41 PM
is there any way to run my own wires from the vtec solenoid to the ecu? so that wat i dont have to go and get the z6 wireharness out of the junk yard??? is lewy rigth about the timing belt haveing 1 less tooth?
Old Jun 4, 2009 | 04:45 PM
I just gave you the instructions for how to do that...
Yea, the timing belt is different. I really don't understand, did you buy the head just assuming it would go on and not do any research at all?
Old Jun 4, 2009 | 04:48 PM
no i ordered a used d15b7 and they sent me a d16z6 so i said screw it and put it on... with out doin some research first...now im having these problems... 75$ and they send me a z6 with the valve cover and solenoid...good deal right?
Old Jun 4, 2009 | 04:49 PM
and when they get a p28 comuter they send it to me for free for messing up my order...
Old Jun 4, 2009 | 04:53 PM
Definitely a good deal.
I am assuming that since you had no knowledge of it beforehand, you didn't remove the oil jet between cylinders 2 and 3 on your D15 block. You will need to do that if you want VTEC to ever work.
Old Jun 4, 2009 | 04:57 PM
now u tell me that after i got everything back togther sept the distributor??? looks like i will be non vtedc for a while....cant waste the gaskets.....no time or money for this right now i just want it to run....trani needs to come out of my girls 94 civic ex....
Old Mar 11, 2019 | 10:04 AM
Craig Kirkland's Avatar
Default you need a 92-95 vx belt it's 103 teeth the deck height is now different from the swa
well i took the belt off to put on the z6 head and now its al back together and the belt is really loose... it wasnt before... i dont understand why the timing skipped if the belt wasnt loose before...
no i dont have the z6 distributor... i have the d15b7 distributor... why are they diff?? cuz of the vtec? i dont have a pcm for the vtec so i wasnt gunna hook it up for now...
can i drive it with out the vtec with out hurting it? i have to get a z6 distributor dont i?
you need a 92-95 Honda vx timing belt. the swap you did changed the deck height. you will skip teeth and jump timing if you don't swap the belts. the vx is 103 teeth opposed to the d16 being like 106 or something like that.
splinterv1
Jul 5, 2011 10:16 PM
carter136
Mar 3, 2010 04:31 PM
candyman420
Jun 6, 2009 08:32 AM
tak2099
Feb 27, 2009 02:18 PM
fletch92hatch
Dec 26, 2007 07:11 AM
