ZC motor in a 4 gen
I was looking to get a fourth generation civic and if I couldn't find an SI version I wanted to do a motor swap. I was reading around a I saw that ZC and D16Z6 motors easily swapped into a 4th gen chassis. I couldn't find a D16s for sale on the web but I found plenty of ZC motors. Are ZC motors worth swapping are parts easily available in case it breaks down. Also are there any performance mods for sale that will fit the motor.
RE: ZC motor in a 4 gen
ZC motor swap is definitely worth it for the money. You can pick up an imported engine for under $600. They bolt right into 4G Civics (same mounts), and they use the same transmissions (you probably want to get an Si or at least a DX tranny for better gear ratios). Also, you will want to find an ECU from an 88 or 89 Integra 5-Speed (don't use the stock ECU). There are a few electrical modifications that need to be done, but they are very simple. If you end up getting a 4G Civic with DPFI, there are some slightly more complicated steps involved in converting it to MPFI. As for parts, there are a lot of sites out there with parts lists for ZC motors. Basically, they just use a lot of parts from a bunch of different Honda engines. I have a list somewhere, but I'm not sure where it is. I've done a couple ZC swaps, both for me and for a friend, and they are very simple. As for aftermarket performance, most performance parts for D16's will fit right onto the ZC, so that is definitely not a problem.
If you have a lot of money to spend, and you want a bigger performance boost, the B18C5 is about as good as it gets, but be warned: they are quite pricey. If you want an inexpensive engine that is still very buildable, the ZC is for you. |
If you find that list with the parts sites on them could you give them to me I would appreciate it.
What kind of fuel injection systems do 4th gen civics beside the SI use. I read an article in Sport Compact Car where they swapped a D15 for a B18 and they had to switch from multi port to direct port. Would I need to do the same thing if I switched to the ZC. Is the wiring complex? And what wiring would I have to do to make the switch.
Could I use the stock drive shafts with the ZC engine and transmission or would I need to Change them.
What kind of fuel injection systems do 4th gen civics beside the SI use. I read an article in Sport Compact Car where they swapped a D15 for a B18 and they had to switch from multi port to direct port. Would I need to do the same thing if I switched to the ZC. Is the wiring complex? And what wiring would I have to do to make the switch. Could I use the stock drive shafts with the ZC engine and transmission or would I need to Change them. If you have any more questions, feel free to ask. |
Does the ZC have multi port injection or does it have throttle body injection.
ZC's have multi-port.
will the fly wheel from the ZC mate to a 4th gen tranny.
yes, it will, provided it's from an Si or DX
