400 whp.....out of a b16
Old Nov 20, 2006 | 05:52 PM
cmasonrun's Avatar
Default 400 whp.....out of a b16
i have a b16 with all stock internals and it burns oil so i have to fix the block, and i might as well build it while im at it....
here is what i was thinking. this is with help from the local tuner shop....tell me what you all think
Block:
b16 block
with either srp pistons or je pistons
eagle h-beam rods
new oil pump, water pump and timing belt
Head:
Crowler chromale retainers
dual valve springs
valve job
Turbo:
precision dual ball bearing turbo sc34 with a .48 exhaust side(hot side)
edlebrock victor x intake manifold
mini me exhaust manifold
custom piping and some sort of FMIC....
tuned with hondata
and here are the prices...
2500 to build the block...
1500 to do the head....
so 4,000 to build the whole motor ready for turbo, this is installed in my car....
so while im saving up for the turbo im breaking in the built motor
and then 4,000 more to build the whole turbo, put it on, and tuned with hondata and on the dyno....
So let me know your opinions, suggestions, and if this is WAY to much money to reach 400 whp.....thats what the shop is guessing....either close to 400 or at 400!!!!
Old Nov 20, 2006 | 08:09 PM
riceburner700's Avatar
Default RE: 400 whp.....out of a b16
i think its gonna take a few more dollars to achieve 400whp with only 4000 unless you cut some corners.
Old Nov 21, 2006 | 07:30 AM
cderalow's Avatar
4000+4000=4000?
8,000 seems like more than enough
Old Nov 23, 2006 | 06:13 PM
gotboost?'s Avatar
yeah your looking at probably 7000-9000 to do the whole rebuild and turbo from a shop. Do everything yourself and its a different story.
Old Nov 23, 2006 | 09:50 PM
jhsplaya08's Avatar
thats what im saying...labor is not cheap. its gonna run you atleast 6 grand probably more around 8 like they said.
Old Nov 24, 2006 | 12:30 AM
Pete's Avatar
8K is more than enough. Get the motor built for 4K And instal the turbo urself, get it towed to a tuner, have them dyno tune it.
Old Nov 24, 2006 | 09:07 AM
Method's Avatar
why do you need 400 whp?? it's just asking for trouble.
Old Nov 24, 2006 | 01:59 PM
Mr Mobsta Man's Avatar
Why is 400 trouble on a built engine? Maybe not gettin any grip in low gears but the engine would be alright.
Old Nov 24, 2006 | 02:04 PM
Method's Avatar
what i meant by trouble is, that your not gonna see the speed limits and use the 400hp all the time.
Old Nov 24, 2006 | 09:14 PM
I dono maybe he wants to drag race.
