95 Civic Tachometer Inopertive Help?
Ok its hard to explain if you take your Instrument Cluster out and you look at the 4 wire clips that connect to the Cluster, the problem lies on the biggest wire collection (should be 10 wires). The wire color sequence goes::
Red
Red/Blk [Spliced open] (Here is where I believe the problem is. An electrical current test shows this wire having no power flow.)
Blk/Yel [Spliced open]
Blu
Yel/Red
Wht/Blue
Grn/Blu
Grn/Yel
Yel/Blu
Yel/Wht
I need to know where the Fuse is to find out if its hopefully blown and I can replace it.
Red
Blu
Yel/Red
Wht/Blue
Grn/Blu
Grn/Yel
Yel/Blu
Yel/Wht
Red - Dimmer
Red/Blk - +12V Power (Fuse 19)
Blk/Yel - +12V Power (Fuse 1)
Blu - Tachometer
Yel/Red - Oil Pressure Light
Wht/Blue - Charging Light
Grn/Blu - Left Turn Signal
Grn/Yel -Right Turn Signal
Yel/Blu - Speedometer
Yel/Wht - Fuel Gauge
Blu - Tachometer
02civcoupe
May 11, 2006 11:09 PM
