automatic door locks
ORIGINAL: renpot
Does anybody know how to programm a 2005 civic to lock doors automatically when you put the gear in "D" or once it hits a certain speed?
Thanks,
Thanks,
I've got a 2006 Civic EX. I know it's a different year model but "maybe" they're close enough together that the proceedure will still work. My owners manual says this feature is available on all LX and EX models. It's worth a try anyway!
Here's what my owners manual has to say on the subject. There are two auto locking modes you, or at least I can select.
To Activate an auto door lock mode: Locks all doors when the vehicle's speed reaches about 9 mph (15km/h).
1. Make sure the shift lever is in Park (P) and close the drivers door.
2. Turn the ignition switch to the ON (II) position.
3. Set the parking brake.
4. Push and hold the brake pedal, then move the shift lever out of Park (P).
5. Push and hold the lock side of the master door lock switch on the driver's door. You will hear a clicking sound (the sound of the doors locking), and after about 5 seconds, you will hear another clicking sound (the sound of the doors trying to lock again!).
6. Release the switch, move the shift lever to Park (P), and turn the ignition switch to the ACCESSORY (I) position within 5 seconds.
To activate an auto door lock mode: Locks all doors when the shift lever is moved out of Park (P).
3. Push and hold the lock side of the master door lock switch on the driver's door. You will hear a clicking sound (the sound of the doors locking), and after about 5 seconds, you will hear another clicking sound (the sound of the doors trying to lock again!).
4, Release the switch, and turn the ignition switch to the ACCESSORY (I) position within 5 seconds.
On my car, I also had to program an auto unlock mode. It worked pretty much like the first example above except that you hold the master door lock switch to the unlock side instead of the lock side.
To activate an auto door unlock mode: Unlocks the driver's door when the ignition switch os moved out of the ON (II) position.
5. Push and hold the unlock side of the master door lock switch on the driver's door. You will hear a clicking sound (the sound of the doors unlocking), and after about 5 seconds, you will hear another clicking sound (the sound of the doors trying to unlock again!).
Good luck & let me know!
Steve R.
Thanks Steve. I will try this tonight. One question though, can I unlock the door manually while the car is running? In case of roll over accident (knock on wood), I want to be able to unlock the doors.
ORIGINAL: renpot
Good luck on this one. I'm curious to see if your 2005 and my 2006 are the same on this point.
Steve R.
Rsporty
Feb 13, 2010 04:22 AM
mpenner
Jun 24, 2008 05:56 PM
