Buy which jack for 1992 civic?
Old Aug 2, 2011 | 01:38 PM
myhondacivicforumacct's Avatar
Default Buy which jack for 1992 civic?
Will a 20 inch high jack lift a 1992 civic's recommended front or rear jacking point high enough to put 11 inch jack stands under the car? I want to use only the manual's recommended jacking points.
Rapid Pump® 2.5 Ton Heavy Duty Floor Jack,
$80
lift range:3-20 inches
Rapid Pump® 2 Ton Low Profile Heavy Duty Floor Jack
$110
lift range:2.5 - 23.75 inches
Rapid Pump® 3 Ton Heavy Duty Floor Jack,
$80
lift range:5-18 inches
Rapid Pump® 4 Ton Heavy Duty Floor Jack
$110
lift range:4-20.5 inches
Rapid Pump® 1.5 Ton Compact Aluminum Racing Jack
$70
lift range:3.25-14.75 inches
Rapid Pump® 1.5 Ton Lightweight Aluminum Racing Jack
$140
lift range:3.5-17.75 inches
Floor Jacks - Save on Automotive Floor Jacks at Harbor Freight
Which should I get? People say heavier is better. I don't care if it's heavy. Any other considerations? Will a higher one let you do more different kinds of repairs?
Ska-T
Apr 21, 2010 12:21 PM
tba02
Apr 29, 2008 07:27 AM
nate081304
Jan 16, 2007 07:41 PM
ltkenbo
Nov 28, 2006 06:50 PM
jcivichb
Jan 12, 2006 10:05 AM
