cam belt / timing belts
Old May 14, 2005 | 04:35 AM
tsangman's Avatar
Default cam belt / timing belts
Hello just another question
I recently got my timing / cam belt changed but car makes a squeaky sound from the engine bay every time the car is pulling off in low gears. The garage told me you got to wear the belt in and noise would disappear but after covering 800 miles the car still makes that sound. Should the belt take that long to wear in or have the garage placed the wrong belt in the car so confused.
Old May 14, 2005 | 08:12 AM
97CivicEX's Avatar
Default RE: cam belt / timing belts
when replacing the timing belt, all drive belts have to be removed. It sounds like one is loose. The screeching sound normally means a belt is slipping(not the timing belt since that one has teeth). I highly doubt they put the wrong timing belt as that will not allow you to turn on the engine.
Old May 14, 2005 | 05:45 PM
sacicons's Avatar
yeah, it sounds like one of the accessory belts is loose, like the alternator belt.
Old May 15, 2005 | 02:19 AM
Kappa22's Avatar
Yup. Alternator belt.
MBrent
25
Oct 1, 2009 12:05 PM
silverbullet01
Nov 9, 2008 06:44 PM
Pete
Oct 13, 2005 11:32 PM
SkweezrW8
Aug 9, 2005 09:02 PM
riceburner700
Jul 15, 2005 12:18 AM
