Can I fix uneven tire wear by myself?
Old Jul 25, 2013 | 02:23 PM
DaHonDa's Avatar
Default Can I fix uneven tire wear by myself?
My front 2 tires are wearing out unevenly. The inner (medial) ring is wearing out, while the outer ring (distal) still has much tread.
Can I fix this problem without going to a car mechanic?
Old Jul 25, 2013 | 03:47 PM
Dara Law's Avatar
I am not too sure but check out the Honda Civic tire and suspension forum, Suspension, Brakes, Tires & Wheels - HondaCivicForum.com. They can probably give you some pointers.
Old Jul 25, 2013 | 08:04 PM
DaHonDa's Avatar
thanks, Dara Law. I posted in the Tire subforum.
Old Jul 25, 2013 | 08:17 PM
GeeIWon's Avatar
Unhappy More Than Likely Not
Looking like your going to need 2 new tires and a alignment...plus maybe more work with front end parts that may also be worn out..
GeeIWon
Old Jul 25, 2013 | 08:29 PM
DaHonDa's Avatar
Mr. IWon,
Thank you for your reply.
Rather than buying 2 new tires to replace my 2 front tires, can I not "turn out" the tires so that the outer ring will now be wearing out much more than the inner part? Won't this then make the wear more even through the tire?
You advised "maybe more work with front end parts that may also be worn out". What front end parts could also be affected?
You mentioned "alignment". I guess that's what I need to have even wear on tires. Can I easily align my tires? I have a home shop/garage with a hydraulic jack and many tools.
Old Aug 2, 2013 | 05:49 AM
vanessar's Avatar
No. you will have to change the tires. There is no partial changing of tires available.. :P
firecatf7333
Aug 2, 2011 04:11 PM
ran2man@earthlink.net
Jul 15, 2009 09:03 PM
uwintoday
Jan 7, 2009 08:38 AM
2X4
Mar 3, 2008 09:57 PM
gunmetal
Jul 29, 2005 05:16 AM
