comprression test
ok i checked my compression in my 95 ex with a d16z6. all pistons were at 140 equally. i'm asuming its 140psi? is that the right spot its suppose to be for being a stock z6? only mods i got is header, HF cat, and exhaust system. runnin 2 1/4 piping by the way...
i dont think your header, cat, exhaust or anything you mentioned matters when it comes to your engine compresion. since all the compression does is check how much pressure the cylinders can hold.
but i might be wrong.
and sorry im not sure what the compression is supposed to be for that engine.
damn i think i do... i've read in my repair manual bout valve lash. never done it though. is it easy? i'm gonna retest my motor in a bit cause i forgot to have my TB open at WOT. i'll give ya'll the update in a bit
The even compression across all four cylinders says the engine is healthy. The absolute numbers you get depend on whether the test was done correctly.
ok i just got done with the whole thing... here's the compression of each.
PISTON ONE: 175psi, TWO: 175psi, THREE: 180psi, and FOUR: 180psi.
wat ya'll think?
i do hear this really slight ticking under the valve cover
wat ya'll think?
