Do I really need a valve adjustment?
Old May 2, 2012 | 08:17 AM
m124's Avatar
Default Do I really need a valve adjustment?
I have a 2003 Honda Civic Coupe. Last time I went for an oil change at the dealership, they said they have no history about me doing any valve adjustment and that I should do it and quoted $198 for it. I called around and regular auto shops don't seem to offer this service. My question is do I really need this service done and if I don't do it, what happens?
Old May 2, 2012 | 12:11 PM
boiler1's Avatar
Depends. On mine, for some reason it says to get a valve adjustment done once at like 20,000mi, and then it never needs to be adjusted thereafter.
It couldn't hurt if you trust the shop because it's easy to mess up. If you run with the valves out of spec for too long you could get a burnt valve, but liklihood probably isn't that big. Usually out of spec valve gap will make the engine tick a lot when the gap is too large.
Old May 3, 2012 | 06:00 PM
If the engine makes excessive tapping / rattling noise especially when cold, it's probably the valve adjustment. The problem is deciding how much noise is "excessive", you won't know that until after adjusting the valves.
DjArcadian
Nov 6, 2010 04:50 PM
Partizan
Jan 25, 2007 09:13 PM
KC4
Jun 24, 2006 02:23 AM
97civicturbo
Jan 15, 2006 12:40 AM
troutman
Nov 19, 2004 05:47 PM
