EK9 and Ej8 the same?
If you have an EJ8 (96-00 EX) you can put on the EM1 (99-00 Si) 13MM rear sway bar, bushings and endlinks. Everything is in place for you so NO DRILLING, FABBING ETC. is required it is a direct bolt on.
Here are the parts
#27 is 52300-S52-A01---SPRING, RR. STABILIZER (13MM)----$67.97
#32 is 52321-S04-003---LINK ASSY., L. RR. STABILIZER----$45.74
#31 is 52320-S04-003---LINK ASSY., R. RR. STABILIZER----$49.49
#34 is 90212-SA5-003---NUT, SELF-LOCK (10MM)----------$0.36-----(2 req'd)
#33 is 90002-S10-000---NUT, FLANGE (10MM)-------------$1.85-----(2 req'd)
#30 is 52317-S04-000---BRACKET, RR. STABILIZER---------$9.67-----(2 req'd)
#36 is 95701-08018-08---BOLT, FLANGE (8X18)------------$0.62-----(4 req'd)
#35 is 93403-08020-08---BOLT-WASHER (8X20)------------$0.16-----(4 req'd)
#28 is 52308-S04-000---HOLDER, RR. STABILIZER-----------$4.14-----(2 req'd)
#29 is 52315-S52-A00---BUSH, RR. STABILIZER (13MM)-----$3.42-----(2 req'd) or you can buy polyurethane ones
Here are the parts
cuongvo85
Apr 22, 2008 01:49 AM
djmerge1
Mar 31, 2008 10:26 AM
1998wagonhatch
Aug 15, 2005 03:36 PM
52300s52a01, 96, bar, chassis, civic, difference, differences, ej8, ej8ek9, ek4, ek9, engine, full, progress, rear, suspension, sway
