F22 swap
I have a 91 civic hatch thats got a D16 in it and i have a buddy with a F22..i was wondering if they can be interchanged...the D16 just got locked up 2day so if anyone can help me i could really use it so i can get the car back on the road
thanx |
They can but honestly, you're better off swapping in another d16 than the f-series. You'll need custom mounts and axles as well as a lot of other things to make the f22 work in your EF. A d-series can be found fairly cheap used (~$300-$500 on Craigslist) and will drop right in (with the possibility of a little wiring work depending on which d-series you swap in).
But yes, the F22 will technically fit in the EF chassis. |
(Post 705924)
But yes, the F22 will technically fit in the EF chassis. so basically its not worth it cuz its cheaper and easier to buy a used D-series and drop it in. |
Yeah, pretty much.
right on man thanx for your help
hey will a D15 swap in...I have a D16 right now?
heres the link if anybody wants to look at it and tell me what they think http://stlouis.craigslist.org/pts/1666308916.html |
It should drop right in. Your stock intake and exhaust should bolt up to it with no modification as far as I'm aware. The only thing that might be a problem would be the ECU assuming he won't give you the one for the D15.
