fail emissions 1999 ex
Old Nov 24, 2008 | 04:01 PM
johnnyboy79's Avatar
Default fail emissions 1999 ex
hey guy,
my first post here!!! so i went to the emissions center i know i have the check engine light on and it fail the code are 1259 manufacturer controlled and air metering plus 0171 system too lean bank and 0730 incorrect gear ratio?? i know how to work on car's !!!!! so what part's are needed to be replace on it to pass emission ???
thanks
jp
Old Nov 24, 2008 | 04:15 PM
When you have the CEL on with more than one code, the first thing to do is reset all the codes then drive for a while and see which ones reoccur. The ones that don't may be from temporary conditions that no longer exist.
Has anyone changed the engine, transmission, or ECU in the car or is it all stock? Incorrect gear ratio sounds like your transmission may not match the ECU.
Old Nov 24, 2008 | 04:21 PM
Codes 1259 and 0730 indicate problems with the VTEC (pressure switch or solenoid) and automatic transmission (clutches, shift control solenoid, or entire transmission), respectively. These are not emissions code per se, but will prevent you from passing inspection.
Code 0171, running lean, is a bonafide emission issue and may indicate a bad fuel pump, fuel filter, fuel injector, primary O2 sensor, valve clearance, or exhaust leak.
Unfortunately, there is no simple answer to any of these codes. Troubleshooting needs to be done to identify the specific problem (download 96-00 manual at link in my signature).
Old Nov 24, 2008 | 04:46 PM
the car is stock and the tranmission it's not good and it's automatic!!!!
Old Nov 24, 2008 | 04:58 PM
thanks for the info and links..
Tiran
Dec 19, 2009 10:07 AM
bdouglas
Mar 12, 2008 04:57 PM
96 civic hatch
Mar 1, 2008 07:37 PM
tknaub
Feb 22, 2008 08:34 PM
Remmy
Sep 1, 2005 07:32 AM
