Headliner removal
first you need to take all the pillers off ,front and back, that help hold the headliner up, then you need to take your dome light off aswell, and you need to unscrew your sun visers as well..at this point you should have nothing solid holding it up, then you just need to put your hand under it and pull down, its held on by velcro...open up your back seats and slide it through your trunk and try not to bend it to much
Take out your back seats, take out the rear interior panels on both sides of the rear seats, take out the rear parcel deck cover, then take off the b-c pillar covers, then remove the center trim cover between the c pillars, then remove the a pillars, then remove the sun visors, sun visor hooks, mirror, passenger grab handel, driver side rear coat/shirt hanger (if so equiped), the the dome light. Now there will be two lil coin shaped push tabs above the rear passenger seat area, you will want to get a pannel remover (the one that looks like a two pronged fork with a slight bend in it for leverage) and slide it under the head of the lil tab (go from the center out)....... If you do not do this you will bend the roof support downward. Those two lil push tabs and the lock tabs on the visor clips were the two things I had problems with (beyond the normal pannels not wanting to release), the lock tab on the visor clips hast to be pushed back. You do so with a lil flat head screw driver from the front side of the clip (towards the windshield) in the lil opening, just push n turn the clip and it shoud turn 90 degrees and then be pulled down n out.
Once everything is removed the headliner will simply fall down since there is nothing holding it in. GO SLOW and you should be fine.... Oh and if you lay both driver and passenger seats flat back you can turn the headliner pull it out either door (just another option over the trunk route)
...there might be slight differences since you've got a sedan...
snosurfa7
Jul 5, 2006 12:24 PM
droolincivic
Nov 24, 2004 12:30 AM
droolincivic
Aug 23, 2004 04:06 PM
