Help With V-Tec
Old Sep 5, 2008 | 04:58 PM
buhrrito's Avatar
Default Help With V-Tec
Does Any One KNOw IF you Can Convert A non Vtec Motor To A V-Tec Motor??
Old Sep 5, 2008 | 05:16 PM
Ozone's Avatar
If you get a Vtec head, ecm, and a few other things, yes...... That's one of the things I'm planning for, when building my new motor.
Old Sep 5, 2008 | 05:26 PM
yea you sure can
check out the Mini-me conversion thread in our DIY drivetrain section
it should tell you a lot
basically you put the VTEC head on your non-VTEC block, pull out the oil jet in the block, put the new ECU in, and run a wire from the VTEC solenoid to the ECU.
that's the basics
P.S. TaLKiNg LiKE DIs is hella annoying and is for 14 year old girls.
Old Sep 6, 2008 | 05:39 AM
babyivan's Avatar
I personally dont see the big deal about vtec, Ive had my EX for 4 months now and I might have dipped into it once or twice. It kicks in at pretty high rpms, and I dont feel comfortable pushing my little 1.6 to the limits.... not to mention the 5 speed tranny probably not liking it.
I would love to throw in a k22 and turbo it...... that's where the real power comes from!
Old Sep 7, 2008 | 09:08 PM
cyberx32's Avatar
Try a DOHC vtec. Thats when you really feel it
Old Sep 7, 2008 | 09:13 PM
that's because you're not supposed to feel it!
there is no kick (assuming VTEC point hasn't been tampered with, or it has been adjusted properly during a tune). it's supposed to be a smooth changeover.
Old Sep 7, 2008 | 09:18 PM
94hondacivicEX's Avatar
the best way to feel sohc vtec is the swap and a cam the fifference in eg vtec and nonvtec is 23hp
Old Sep 7, 2008 | 09:19 PM
and the cam can make the difference even more witha bad *** intake manifold and exhaust
Old Sep 8, 2008 | 07:25 AM
babyivan's Avatar
I think you quoted the wrong post, I never mentioned anything about whether I feel "it" or not, I just dont see all that big a difference between the SOHC vtec and the SOHC non-vtec.
I agree with cyberx32 about the DOHC.... then it probably makes a difference whether you have vtec or not(of course we all know the DOHC motors only come with vtec).
My initial point was, I dont think it's worth it to convert a SOHC non-vtec to a vtec..... better off with an engine swap to a B or K series.
Old Sep 8, 2008 | 10:52 AM
I read wrong. I thought you were referring to kick as an actual kick. You meant something entirely different.
That's incorrect.
There are many non-VTEC DOHC Honda motors.
For example, the Integra LS motor.
