How much boost can I run in a Stock D16
Old Sep 3, 2007 | 06:08 PM
t34me's Avatar
Default RE: How much boost can I run in a Stock D16
do a lot of research for the love of your civic, and also for the love of your civic please lose that wing, your car is FWD.
nyorkrider's Avatar
it shouldnt blow the motor if you turbo it, but I wouldnt run it over 7 pounds
Old Sep 3, 2007 | 07:19 PM
FlipHKD720's Avatar
ORIGINAL: knoklu
dsm t25, its a smaller turbo but spools up real quick and there real cheap used or rebuilt if your on a budget like me lol still in school.
T25s are pretty common, they're ineternally gated at 8psi so it simiplifies things a bit, and thats about the PSI you want to be running with them anyway. They can be picked up for fairly cheap and spool quickly, pretty much what you want for a DD IMO. At 8 psi, you'll prolly be a little bit below 200 hp so you should be safe with that. I picked up a VJ11 turbo out of an old Probe/Mazda ant its internally gated a 7 PSI. its really similar to the T25 so that will work as well, but you wont be able to find htem as easily at T25
Old Jan 19, 2021 | 09:49 AM
Cody C Thongtavee's Avatar
Originally Posted by Littlehag
I'm really interested in getting a turbo for my 99' ex with a D16 engine, but.. I don't know if its worth the money, or if it'll blow my engine down the road.Would it be more worth my interest todo an engineswap with say.. a b16? back to the D16... What type of turbo can I run without pushing my engine over the limit and causing me even more money. The engine right now has a3-2-1 header with a full exhaust, anda lot of dress-up items that were on it whenI bought the car. I am aware that I will need to upgrade a few other things, like the ecu and fuel system. but the thing I don't know is how much of the fuel system I will need to upgrade. just the injecters? or a new fuel rail and pump also? I need lots of help guys.
I have a stock ex motor (d16y8) bolt on turbo and tuned. I’m currently running 9psi and I daily it. As long as your not ******* the car everyday everywhere you go you’ll be fine up to that range. You start driving like a pissed off teenager then you’ll blow your head gasket or cause a major issue. But I stress it’s all how you drive it. I’ll list my current set up below..
Motor- Bone stock d16y8 from a 98 ex (obd2a)
add ons:
-AEM 340lph
-FIC 1000cc injectors
- GT35 Turbo .70ar(compressor) .93AR(turbine)
- 2.5” charge piping
- Mishimoto M Line intercooler
- HKS SSQV bov
-AEM AFR
- PLM top mount manifold (modified for gt35 turbo)
- skunk2 mega power RR 76mm(3”) exhaust
-custom 3” test pipe
- 3” downpipe
- precision turbo 46mm wastegate with atmospheric dump tube
-Hondata s300 V3
like I said the motor is completely stock internally I’m running the stock fuel rail for now stock fuel filter it’s putting around 220-250 to the wheels after the tune. But again I drive it most days like I would a regular car and don’t abuse it. I do regular oil changes and just keep checking gaskets and seals for leaks to stay on top of it.
angelo84
Jan 17, 2020 12:07 PM
Max713
May 27, 2008 11:26 PM
tombakers
Nov 20, 2006 08:53 PM
Pete
Jan 16, 2006 12:18 AM
Remmy
Mar 6, 2005 01:18 PM
