How to put car on four jack stands?
sounds scary to me. I am gun-shy about that stuff because once I used a jackstand on grass and it tipped causing the rotor to fall on my hand.
If I were you, I would use cement blocks and jack stands just to be safe. And make sure you are on level cement although its common sense for most people except me.
Yeah, I was always afraid to try it, but it would be really convenient for changing the brake fluid. That sounds like it really hurt. How many bones did you break?
It is real easy to put your car up on 4 jack stands. Mine in up on 4 right now. I jacked up the front of the car put to jack stands under it. Let it down and went to the back of the car. There is a spot to hook a toe strap under the rear bumper. I just jacked up right there and placed jack stands on eack side of the car in front of the rear tires. It is simple to do.
Like Maximus said, don't attempt to do that on dirt. You need a level concrete floor.
It's possible to reach the brake bleeders just reaching underneath once you have them broken loose. Put the rear up on ramps and turn the front wheels to one side or the other depending on which caliper you need to reach.
I don't think the question has been answered yet. Exactly where under the car do you put the jackstands if you are doing something like replacing suspension parts? MaximusFunk, you are lucky they are not remembering you on the Darwin Awards site.
Now back to the question. I'm sure you can put the stands under suspension parts but will that prevent you (or in this case, me) from doing what I need to do if, on the offchance, I find that after a mere 228,000 miles, the '91 Civic wagon needs some new balljoints, shocks, brakes, etc.
I was thinking the exact same thing while reading this thread. I also have a need to sometimes put my car up on 4 jackstands.
And your comment about the Darwin Awards..couldn't be more spot on.
So here's how I would do it:
Put a jack under the middle of your subframe brace in the rear. Don't worry, this is a structural part of the car. Jack it up from there until you can put jackstands under the tabs that Honda has. Those little metal tabs on each side of the car. The factory sideskirts have arrows pointing to them. There are two in front of the rear wheels, and two behind the front wheels.
So you now have the rear suspended in the air.
The front is a little trickier, but here's how I would do it. Put a jack under a control arm mount in the front and lift on side of it. You can only do one side at a time this way. When you get that side high enough to put a jack stand under the tab/mount, do it. Then move onto the other side. then you have your car on 4 jack stands
