Im new and need help
Old Jul 3, 2016 | 08:25 PM
2011Civic's Avatar
Default Im new and need help
I have a 2011 Honda Civic, 1.8, auto base model.
Now my problem is that out of the blue one day I got in my car after it had sat in the Sun for about 2 hours, as I started to drive it there was this whining noise coming from the front of the car, when I depress the brakes the noise either quiets down or stops altogether the noise does not happen while I am moving forward. And it doesn't seem to be happening if the car is either not in direct sunlight or not up to operating temperature. I have checked all my fluids and they are good.
Thank you for your help.
Old Jul 19, 2016 | 05:03 PM
itburnswhenIP's Avatar
it could be your brake pad wear indicator or maybe a sticking caliper piston,remove the caliper and lube up the piston.
Old Jul 25, 2016 | 09:27 AM
Jaredarchuleta5's Avatar
Default Brakes
You need new brake pads buddy either that or you have dust, dirt and grime in your break boots or brakes. Try spraying them down with the pressure washer at the car wash and if it persists then get your brake pads changed out with some new ones.
SPACEGUY18
Nov 20, 2009 02:01 PM
Joe The Bird
Feb 19, 2008 04:05 PM
Rockstar
Apr 14, 2006 03:26 AM
wicked1z
Feb 20, 2005 05:52 PM
injctd
Jan 4, 2005 09:33 PM
