Miami Turbo Civic
Old Oct 13, 2012 | 04:31 PM
Miamifiremedic's Avatar
Default Miami Turbo Civic
Whats up everybody. Ive got a 98 sohc t3 turbo civic on 10lbs. The motor was overheating before i dropped the turbo ( went high once and inadded water been fine after that) so i figured it was thermostat. So After removing the thermostat and adding a sealant it doesnt heat as much but still..White smoke out of the tail pipe and im adding water everytime i go out to be safe. It runs great and ill add some video soon.
Any advice or does Anyone recomend any shops? Ive gotten quotes for replacing the head gasket for 700 including parts and labor ( 5 day job he says )
Ive thought about dropping a new jap 1.5 motor which a shop told me is a regular when it comes to replacing motors.
Helppppppp
Old Oct 15, 2012 | 03:50 AM
danomatic93's Avatar
June 2010 ROTM
...5 days?? This should be an afternoon project unless you have some crazy ghetto turbo setup that makes it difficult to service. If you run with a bad headgasket long enough your piston rings will be shot too. How's the oil consumption?
Old Oct 16, 2012 | 02:56 PM
T3/T4 TURBO INTERNAL WASTEGATE SET TO 10PSI
WRAPED MANIFOLD
WRAPED INTERCOOLER PIPING
GREDDY BOV
A/C FRIENDLY
DOWN PIPE WITH CAT DELETE
CHIPPED P06 WITH JUMPER HARNESS FROM OBD2 TO 0BD1
REV LIMIT AT 7500RPM 2STEP AT 4000RPM AND VTEC POPS AT 4500RPMS
CHIPPED ON CHROME TUNED ON 10 PSI ON A D16Y8
450CC INJECTORS WITH RESISTOR BOX
5 days because he's backed up. I've called a few people and I found someone else who can do it. I'm more worried about the block than anything else. I just finished paying for the inlaws tranny so this couldn't have come at a a worse time. Whatever well see I guess.
I check the oil and it looks good not watery or
Low. For now I'm driving it slow and filling up with water before I go.
Thanks for the reply.
mrbags
Sep 16, 2012 05:05 PM
HadesMR
May 14, 2008 03:18 AM
point break 92
May 3, 2008 03:52 AM
point break 92
Apr 29, 2008 06:38 AM
jdmhatch
Jun 4, 2006 12:35 PM
