My 2002 Honda Civic EX, Keeps dropping from 70mph to 20mph after driving for 30minute
Dear Forumers,
I need help, have run out of options.
My 2002 honda civic EX has been dropping in power/stalling/stopping on the highway after I drive for 30min or more. Its drops from 70mph to 10mph, and it will only drive ok after I sit the car down/stop/cool for at least 45min. The problem comes right back soon after i drive for 15min after cooling/stopping/resting the car.
This is what I have done so far.
1. I went to Honda dealer Ed-voyles honda and got a diagnosis
they told me the code was O2 sensor and it could also be the Catalytic converter
2. I changed both O2 sensors as well as the whole catalytic converter but the problem was not solved.
3. I came to this forum to find possible causes of this problem... and since then I have changed the following based on what I read here
a)I changed the Fuel filter and checked the fuel pump to make sure its working (and it does works fine) I switched the gas from regular to premium and put in engine cleaning fluid in there and tried to run the car for a while
b) I took apart the air intake manifold and cleaned the whole system and tried to test the throttle position sensor as well
c) I have changed the ignition switch with brand new one from honda
d) I have changed the ignition coils with brand new ones from honda
e) I have put in brand new iridium spark plugs
f) I have changed the thermostat
g) I have changed the engine coolant temperature sensor
h) I have changed the main relay (three relays under the glove compartment- 1 blue= fuel relay, 2 brown =engine relay 3 black = ??)
The problem still is not solved.
Please can anyone help me solve this problem. I desperately need help.
Thanks
lnarthur
Thanks
lnarthur
Shane Dodd
Jun 9, 2012 06:01 PM
briceman124
Sep 23, 2011 01:44 PM
scribebox
Jun 11, 2009 09:42 AM
