need engine tech help
Guest
Posts: n/a
hey i head a horrible nock in my engine,
it was so bad i couldnt drive over 35 mph,
so i havent drivin it for a month.
and i finaly took the oil pan down to take a look.
and the bearing were done. they were ok looking just you could tell they were worn away, all but three of them.
if my block is fine looking would it be ok just to throgh on a new set of bearings?? and if so how owuld i flush the engine out of the little flakes of metal?
thanks
thanks
I'd just start looking for another motor. If you have metal in the oil, there is no telling how bad the damage is. It could end up costing a hell of a lot more to fix the motor than simply replacing it.
you can repair your motor as i mentioned before on your other thread, you will need to buy a new crank and replace the crank and rod bearings, or if you have a engine machine shop drop th crank off to them and have it turned .10 over and buy new oversized crank bearings.
Guest
Posts: n/a
thanks i understand that.
but what if my crank is still fine?
like the metal i saw was comming from the bearings.
like i said my block isnt scratched and it appears to be fine.
a machine shop said that they will machine a new crank for 250. and i would have to get over sized bearings. then replaces the oil pump, so thats about 500.
and thats if i all put it in my self.
and i found a 1.5 jdm d16b for 650
u mean a d15b,
you say it looks good but ive worked many years at a engine machine shop building engines, when bearings go bad they put grooves in the crank, and even if you do put new bearings (with is just a metal sleeve and not an actual bearing) the worn grooves in the crank will just ruin the new bearings and make your engine knock again.
500$ to turn the crank and put a new oil pump is way way to much, ur saying they wanna charge 250 for the crank and 250 for a oil pump ...?????
you can just buy a new crank at autozone for way way cheaper and im pretty sure they come with new bearings
Yes they shave down the crank so it is smooth again, then use bearings that are thicker than stock to compensate for the lost metal. The clearance between the crank and the bearing is very small and critical. The way a plain bearing works is that the metal never touches, instead it rides on a layer of oil in the gap. This requires the metal to be very smooth and exactly the right size, and of course a constant flow of oil.
It really is a lot simpler to swap the whole engine, having a guarantee on the whole engine from whoever sold it. If you try changing parts inside the engine there's no guarantee that there won't be other problems, and it can quickly become a waste of money.
the reason i said you can have your old one machined is to smooth out the grooves made by the old bad rod bearing,
