remote lock does not work
Hi
I have a Honda Civic 2000 LX, problems: Remote lock does not work Manual lock/unlock on driver seat does not lock/unlock the right passenger door. Any suggestions on how to deal with this? anything like do-it-yourself kinda thing here? Regards Raghu |
Originally Posted by s_raghu77
(Post 759592)
Hi
I have a Honda Civic 2000 LX, problems: Remote lock does not work Manual lock/unlock on driver seat does not lock/unlock the right passenger door. Any suggestions on how to deal with this? anything like do-it-yourself kinda thing here? Regards Raghu About the second problem, are you unlocking with the key or are you using the power lock on the door panel? Only the power lock will unlock the right passenger door, and if the fuse is bad the power locks wont work. If the fuse is good check the battery in your remote. |
Even if I use the power lock on the driver left hand panel the door on the right passenger does not operate. Manually it needs to be locked and unlocked.
Do you mean to say that it is the same fuse which is giving this problem? |
(Post 759615)
Do you mean to say that it is the same fuse which is giving this problem? If some or all of the doors unlock/lock when you use the power lock switch on the door panel then your problem is definatly the remote (most likely the remote battery). If only some doors unlock when you use the power locks (either the remote or door panel switch) then your probably going to have to work harder to get it fixed. |
| All times are GMT -8. The time now is 05:43 AM. |
