Should I buy this Hatch?
Its a 1993 honda civic Hatch. He is asking 9000 for it but i bet i could get him down to 7500 or 8000 maybe. What do yall think...Opinions please...
[IMG]http://i58.photobucket.com/albums/g2...4/c496bff2.jpg[/IMG] [IMG]http://i58.photobucket.com/albums/g2...4/8450b8dc.jpg[/IMG] [IMG]http://i58.photobucket.com/albums/g2...4/f1e0232f.jpg[/IMG] [IMG]http://i58.photobucket.com/albums/g2...4/c1ad9b33.jpg[/IMG] |
RE: Should I buy this Hatch?
wow that hatch is clean as a whistle.
Yeah thats what i said..Im trying to look at it this weekend...Should i buy it?..
How many miles does it have? What are the different mods (looks like turbo and some other aftermarket parts from pic)? Did you ask him why he's selling it? No matter how nice a car looks you never know unless you dig deep. Get the pin number also.
If that car has more than 100 thou I wouldn't buy it for that price. |
holy cow that is a clean hatchback!!! i would drive it just to double check if there are any problems
93 Civic Hatch
Exterior: -Painted Nissan 350Z Daytona Blue. Car was completely stripped and then redone. All body panels were pulled(fenders, doors, hatch, glass, etc). Everything has been base/clear coated in Daytona blue. All jambs have been base coat/clear coated including, trunk, doors, and bottom of hood. Entire engine bay was also base/cleared. The exterior of the car is perfect with no dints or dings. There are no rock chips out of the paint on the front either. $3300 -5% tint on all the side glasses and the rear hatch (lifetime warrantee on it) $200 -Aftermarket rims -Smaller sport mirrors color matched to the car -JDM Thin Side Moldings base/cleared to match the car $200 -New window sill moldings -Shaved rear emblems and key hole for the hatch. Shaved rear wiper arm/motor -Every bolt in the engine bay has been replaced with polished stainless. -Clear corner lenses Engine short block: $2500 with blue printing and assembly -D16y8 low mile block -CP Pistons -Crower Rods -ARP head studs -Crank crack checked, micropolished, and balanced -New bearings -New water pump -New d16z6 oil pump – The y8 pumps are not that great to run on built set ups. Therefore the z6 pump was chosen. Because the y8 normally has the oil dipstick on the pump, a custom oil dip stick was fabbed to check the oil level with this set up. -New Honda timing belt and tensioner -New alternator belt -Alternator rebuilt -All new seals / gaskets -Poly engine mounts Head: $2600 with assembly -D16Z6 head $129 – hot tanked and glass beaded $74 – resurfaced $150 -Brand new OEM distributor $239 -Zex 59300 cam $250 -AEM adjustable cam gear $147 -Ported and polished $540 -Zex Valve Springs $182 -Zex Titanium Retainers $243 -Upgraded Locks $71 -Competition valve job $270 -New Ferrea valve seals $50 -New vtec solenoid $125 -NGK Wires Turbo set up: $3944 -Custom one off top mount manifold $1200 -ceramic coated to keep the heat in the pipes and out the engine bay $155 -Precision SC61 turbo $899 - turbo has been show polished on the cold side and ceramic coated on the hot side $150 -Front mount intercooler rated for 500 hp -2.5” one off intercooler pipes – mandrel bent tubing and tig welded -Silicone couplers / t bolt clamps $80 -Tial 50mm blow off valve $233 -Turbonetics Manual boost controller $86 -Turbonetics thick turbo gasket $16 -Billet oil drain 10an adapter block $25 -Stainless braided 10an drain line -Stainless braided 4an feed line $100 for the feed and drain line kit -Turbonetics race gate wastegate(overkill but its what I had left over from another project) $400 -3” one off intake pipe that pulls air from the driver fog light hole in the bumper -K&N style air filter Exhaust: $650 -Full 3” turbo back exhaust - mandrel bent and tig welded. Down pipe ceramic coated silver($75) All exhaust, including the muffler and resonator, from the down pipe back is -ceramic heat coated flat black. -3” stainless flex section -3” in/out resonator -3” in/out Dyno Max straight through muffler -Down pipe also heat wrapped to keep more heat out of the engine bay $20 -5 Bolt / 3 bolt flanges and gaskets for exhaust connections $55 ECU / Tuning / Fuel: -P28 chipped, clear Plexiglas ecu cover $195 -Tuning $450 -Motorola 2.5 bar map sensor $25 -Brand new OEM Honda oxygen sensor $65 -1000cc injectors $392 -Impedance conversion for injectors $15 -Walbro 255 Fuel pump $100 -New OEM Fuel Filter Transmission: $1300 w/o install cost for the LSD -Low mile Ex 5 speed close ratio transmission -Complete rebuild -All new bearings -OBX LSD installed in transmission at time of rebuild -ACT Xtreme pressure plate with 6 pad disk -The clutch drives great. It does not chatter at all and holds the power perfectly. -Short shifter -Poly shifter bushings -New Slave and Master Cylinder Cooling: -160 deg. Thermostat -Upgraded cooling fan with fan shroud -All new radiator hoses -New Waterpump -New OEM Del Sol Vtec dual pass radiator Powdercoated mirror gloss black: $660 total -Valve cover $85 -Water pump hard tubes $15 -Battery tray $35 -Intake pipe $50 -Intercooler pipes $140 -Intake manifold $125 -Fuel filter bracket $15 -Coolant bottle bracket $15 -Thermostat housing $15 -Oil pan $80 -Battery hold down bracket $15 -Other small random engine bay brackets/bolts $70 total -Every bolt in the engine bay replaced with polished stainless or powdercoated black, unless it was not realistic to coat them (oil pan bolts, shock nuts, a few other bolts) Suspension: -New ball joints in front suspension -Ingals front camber kit, rear shimmed with new grade 8.8 bolts to fix camber -Ground control coil overs on the rear and custom rate drop springs on the front -Car was just aligned by Ron Ellis – front and rear -New Front brakes installed -Every part on the suspension has been removed, inspected, and replaced if needed. Interior: -Converted to black interior from light grey color: -Door panels -Dash -Carpet -Seats -Center console -Seat belts -Door sills -Various other trim pieces -Autometer oil pressure, autometer boost/vac, and a no name water temp gauge. -Bride steering wheel…driver and pass. air bags have been removed from the car Other Info: -Under the carpet, all the interior floor metal has been redone in chassis black while the car was apart. I just thought I would include that since some people strip everything out their cars out for weight savings. The car should be under 2000 lbs easily w/ no air bags, no ac,no power steering, and crank windows. -My amp, sub, etc. will not be included with the car since they came out of one of my other cars temporarily. -The engine was tuned to be reliable for roughly 350 hp for pump or 450 hp for race gas. I would rather have a safe tune and leave some power on the table. -This car was built from an empty shell. Every part has been redone on the car. After finishing all of the work it has only had 1000-2000 miles put on it. The car runs and drives great. It’s a quick fun car but I simply don’t have the time to enjoy it and could use some money to pay for college. I really hate to sell it after all the time I put in it but college is more important. I have pictures to document the entire build and pictures to verify the internals of the engine. I have most all of the receipts for every part on the car. -I spent a lot of time making this list so that you would know exactly what you are getting. I’ve tried to list the price for all of the major things on the car. As you can see I have roughly $19,000 in parts on the car w/o the install or labor costs. I’m asking $9000 obo for it. If you have any offer, email me. You won't offend me, like some people get. If you have any other questions feel free to ask me. |
cleeeeeeeeean
Wow, that sounds pretty good. That car has more stuff than I thought by the pics. I was kinda drooling reading that list lol.
yeah when i was reading it just kept going..My eyes got like bigger and bigger...Cuz im only 18 so you know im still young.But yeah i hope i can see it this weekend...More opinions wanted...
lifes' short. buy what you want.
