Tire pressures?
I have to admitt, I've never owned a little car before, just trucks... and I always inflated my truck tires to about 20psi below what the sidewall says...
Today I noticed my tires are looking a little low... they are 205/15 tires... what pressure should I keep them at? |
RE: Tire pressures?
I checked the sidwalls, they say max 44psi and they're at 40psi but they look low to my eyes....
RE: Tire pressures?
if the max on the tires is 44 then 40 should be ok. u dont want to have it too high especially if its hot out on most day where u live, could blow the tire..
RE: Tire pressures?
i usually try to keep my (175/70/R13's) at arround 35psi, when cold, then when they heat up they usually get to about 40psi, so i dont over do it
RE: Tire pressures?
Your front wheels will always look a little low because the weight of the engine is over the front wheels. If you've properly inflated the tires to the sidewall specs, you'll be dandy.
RE: Tire pressures?
i got mine at 40 all around also
RE: Tire pressures?
38 front
36 rear cold pressures, 195/50/R15 |
RE: Tire pressures?
psi is different for every type tire....as long as u stay under the max psi that ur tire says for daily driving then u'll be fine.
RE: Tire pressures?
the tire doesnt know what kind of car its on... so you go by what it says inside the door jam.
RE: Tire pressures?
I thought the info plate pressure went out the window when you changed tire size?
