wheel help anyone???
so ... im new to all of this. im 15 and im lookin around for a civic and parts for it, ect. im just curious but whats the best offset for '16 inch wheels and wont rub?
With 16x7's and 205/45-16 tires, offset won't make much of a difference unless you're lowered. If you are lowered, you'll want about a +42mm offset. You can get away with anywhere from +38mm to +45mm offsets (probably a wider range, but this is just what I know for sure), and if you're tucking tire you'll want between a +42mm and +45mm offset (this seems to be the sweet spot). With a +45mm offset, you run the risk of the inside of the tire rubbing on the wheel well around sharp turns (but I doubt this would happen unless you're ridiculously low).
ahh. okay cool ... i was thinkin about lowering it about an inch and a half or two (once i get one haha) so anywhere between +38 to +45 should be okay??
Yeah, pretty much. I'd still try to find between a +42 and +45, maybe as low as +40. With the +38 you might have to roll your fenders depending on the drop.
okay thanks man ... il keep that in mind when looking around.
