Engine tuck and Engine bay shave
Old 04-12-2010, 02:10 PM
fabmaster's Avatar
I just did some more blasting today (trying to beat the rain) and I'm designing the linkage to tuck the pressure assist and a mount to tuck the wiper motor but still use it.
I made some calls and I am going to be able to use someones tig later this week. I am tired of blowing through the firewall with my fluxcore.
  #22
Old 04-13-2010, 02:52 PM
fabmaster's Avatar
While I wait to use my friends tig I decided to get some other things done. I am tucking the wiper motor but I am still going to be able to use the wipers.
With the motor, removed the motor and started making a new bracket for the motor. Every bolt was at a different angle which made it fun.
Then I went inside and started cutting out metal for the new motor placement.
Set in the motor to get an idea of clearance.
After some more trimming I made legs to attach the motor to the car. I used some temp hardware to mock it up.
Once I weld the original driveshaft hole and mount holes shut, this will be a functional wiper motor tuck.
  #23
Old 04-13-2010, 04:49 PM
danomatic93's Avatar
June 2010 ROTM
Wow! Props on the wiper motor tuck! Way to go the extra mile!
  #24
Old 04-15-2010, 06:22 PM
Kenny-g's Avatar
I'm Spock Dammit!!!!!
nice work with the mod there mann haha keep up the good work
  #25
Old 04-16-2010, 06:37 PM
fabmaster's Avatar
I've been working on the linkage to transfer the forward motion of the brake pedal, to a lateral motion to plunge the pressure assist once it is mounted inside the firewall. I started with cardboard templates and then transfered the idea to sheet stock.
Since this is for the brakes, I don't want to risk a lightweight setup, so I welded on a layer of thicker stock once the bends were right.
I tested and retested until I finalized the pivot points for the most motion with the least binding.
I'm using the stock pin hole through the brake bedal bar for my first linkage point. I had to make a bracket to lock into that hole and then transfer to the plate I just made
Here you can see the stock hole once the original pressure assist bracket was removed. I mounted my new bracket and then installed the plate. From this I was able to build a mount for the pivot point.
I welded in the bracket for the pivot. You can see that when the brake is pushed, the plate transfers the motion sideways. I still have to mount the pressure assist and then weld up an arm to link the end of the plate to the plunger.
I'll be mounting everything this weekend and then I can post pics that better show what is going on.
  #26
Old 04-17-2010, 05:46 PM
Kenny-g's Avatar
I dont understand any of that stuff so those last pics didnt help me at all haha me confused but u do some really nice work!
  #27
Old 04-17-2010, 07:35 PM
fabmaster's Avatar
Hahaha, yeah, it's not that clear unless you can see the whole picture. Hopefully these will help explain things.
I built a new mount for the pressure assist and got multiple anchor points to make everything solid.
Here you can see why I needed to make the forward motion of the pedal turn 90 degrees to plunge the pressure assist. It is now inside and turned 90 degrees. Don't mind the spider web, I have the previous owner to thank for a hugh cluster-f@%k.
Now when you look through the steering column brace(which was nice and open for my new bracket) you can see that the plate I made lines up with the plunger and all I have to do is make a bar that connects the two.
  #28
Old 04-17-2010, 07:40 PM
Kenny-g's Avatar
Ah that does make sense now haha nice work dang this car is gonna be sick as hell once its done but thats an odd place to put the brake pump but its for a show car not practicality lmao
  #29
Old 04-17-2010, 07:50 PM
fabmaster's Avatar
Glad it's clearer now. It is an odd place, but I will have a center channel speaker above it so if I need to check/fill the fluid, I just have to take out four screws. This is my show car but it is also my DD. I'm just lucky that I can drive my gf's car while I do this overhaul.
  #30
Old 04-17-2010, 08:02 PM
Kenny-g's Avatar
Hahahaha way to keep ur priorities straight and ur gf in line lmao jk jk
Quick Reply: Engine tuck and Engine bay shave
