My z6 Turbo Build
Old Jan 30, 2007 | 10:45 AM
mill$civic's Avatar
Default RE: My z6 Turbo Build
Keep us posted!
Old Jan 30, 2007 | 10:48 AM
cpl rampage's Avatar
yah, 3 inches is prolly overkill, 2.5 would be fine, and a 2.5 inch intercooler is cheeper too. as for HP goals, im looking for 250+, and yah i know it needs a bath, im striping it right now, and then ill have the block boiled, just so its clean inside and out.
Old Jan 30, 2007 | 02:22 PM
Remmy's Avatar
To get the crank bolt out you need to get this hard to find substance that you cant get out of any store nor import it at all.
Its called: Elbow Grease
Old Jan 30, 2007 | 03:36 PM
lol, deffinatly using elbo grease, its just tuff cause its sitting on the floor ands i cant brace it very well, i got some pb blaster on there, letting it sit, and went at it with the breaker bar and a ten foot pole, but like i said i cant brace it anywhere, ive got to go to work today, but ive got tommorrow off from school, so maby ill wedge it under somthing and try again, oh and i took off the head today, and the cylenders look great, amost no scoring, only one or 2 lil virticle scratches total, and, i can still actually see the hone marks, this thing has been babyed
Old Jan 30, 2007 | 03:47 PM
Remmy's Avatar
If you stick it on a motor mount thingy to hold it in place you should have to much of a problem.
Old Jan 30, 2007 | 05:00 PM
Kedawei's Avatar
Try DSM 450 injectors. They are teh cheap.
Alsoget a zex or similar cam if you can afford it. It's cheap for the gains. I'm hoping to grab an Akmee cam next winter when they re-run their holiday special (funds/progress pending).
Get a new timing belt also.
Old Jan 30, 2007 | 06:48 PM
yah, i my friend is leting me borrow his engine stand, but we havent had the time to get together and get it out of his garage
as for the cam, ill definatly look into it, and of course im getting a new timing belt, and all the seals and gaskets are gonna be replaced
Old Jan 30, 2007 | 08:58 PM
Kedawei's Avatar
Just mentioning it in case you had forgotten (it's not in your list).
Old Jan 30, 2007 | 09:07 PM
deffinatly a good thing, i would rather be reminded a hundred times, then run in to problems down the road
i was also talking to my friend at work, and he works for a company that builds and repairs fire engines, once i get it down to the block, hes gonna take it for me, steam blast it, and then an acid wash it
Old Jan 30, 2007 | 09:31 PM
t34me's Avatar
Sounds like a good build, can i recommend agreddy type-s BOV, i love mine, it does the sputtering blow off, not just one big WOOOSH, more the: TSSS....TSssss. tsssss....whatever, just trying to help
